Nice info.
The USA used them a lot and modded them, but I'm sure that's they didn't have the ubiquitous and superb 18R-G to play with.
seeyuzz
river
THE 22R/22R-E THREAD!!!
So far I can't find a single thread about this engine on Toymods, so I made this thread
This is mostly off the Toysport site, but I wrote this a while ago to make it shorter (plus I wrote it for school).
History
The 22R motor initially debuted in 1981, being featured in the Hilux, Corona and Celica. These were the most popular Toyota motors in the US and because of this, there is a lot of aftermarket support in the states. The 22R-E appeared as early as 1982, but came into use at 1983 in Celicas and Hiluxes. The reason for the 22RE's success in the states was that the US only ever recieved the 22R-Es for the Celicas. So race homologation was a factor, and companies strived to make the 22R-Es to run on par with BMWs and such in their same series. Many of the companies would have rathered the 18R-G but they were not allowed to. While running the 22R-E, some were able to beat the cars with 240hp Ford engines. The reason for this was the 22REs torquey power band. The turbo versions of the 22R-Es (22R-TE) were around for a short amount of time between 1985 and 1988 on the Hiluxes. People in the states would just get this engine and swap it out with the 22R-E. It is not possible to use this turbo setup with the standard 22R-E with standard internals since the 22R-TE runs a lower compression ratio. The 22R-E just can't handle the boost stably.
Modifying the 22RE
This is basically all Toysport from here: http://www.toysport.com/technical%20...tech_notes.htm
I will just post the recommended setups here
For stock configuration- the 20R / 22R / 22RE engines are very easy to work on. Due to different emission requirements for the different model years, try to work on the original engine. Porting the head will increase breathing and will not hurt emissions- so basically to stay legal and improve performance- the cylinder head must be ported. The early 22RE pistons can be used to upgrade the 20R to 2400cc.
For modified configuration- the 20R head on top of early 22Rs will instantly give higher compression. All heads must be ported with big valves installed. Be careful of camshaft choice, just remember that all slow modified 20 / 22R / 22RE engines have been over-cammed. Do not try to install cams with duration over 280 on single carb or fuel injection models. Twin side carburetors are the best way to go. For limited budget use the Weber 38 DPS. Headers installed with 2 3/4" exhaust will be optimal. A heavier flywheel will help 4WD models, that should also have the gear ratios changed to compensate for tire sizes.
For racing configuration- basically these engines are truck engines. For off-road truck racing and high performance street use (both pick-ups and Celicas) the Toysport Spec SCORE / HDRA set-up is reliable and impressive. See the parts list for the 20R / 22R engines.
Although we have successfully used the 22RE in circuit racing and rallying, and truck off-road racing- the only reason these engines were used was because of the race regulations. The handicap is the block configuration- which was built for torque and longevity- meaning slow and heavy. The cylinder head modifications, if properly done increases head flow by up to 200%.
For turbo set-up- forged pistons, ported head with open chambers, big valves, TO4 or CT26 turbo, 3" exhaust, mild cam, Carillo Rods, boost controller, blow-off valve and keep the boost under 25 psi!!
/end of Toysport info
Specifications:
Now I'll post the different specs for the 22R-E info gathered from the Haynes manual for an RA65
General
Oil pressure (22R-E)................................................ ........................... 71.1 psi at 3000 rpm
Compression Pressure
Standard.......................................... ............................................. 171 psi
Minimum........................................... ............................................ 142 psi
Maximum difference between cylinders......................................... ... 14 psi
Capacities:
Engine oil (with filter change)........................................... .....................4.65L
Cooling system............................................ .......................................8.55L
Approx
Ignition system:
Spark plug type.............................................. ...................... Champion NY11YC
Spark plug gap............................................... ...................... 0.032 inches
Distributor point gap............................................... ............... 0.018 inches
Dwell angle............................................. ............................. 52-degrees
Ignition timing............................................ ........................... 8-degrees BTDC
Firing order............................................. .............................. 1,3,4,2
Cylinder numbers (front to rear)............................................. . 1,2,3,4
Valve clearance (Hot engine)
Intake............................................ ...................................... 0.008 inches
Exhaust........................................... .................................... 0.012 inches
Idle speed
Manual............................................ ................................... 800 rpm
Automatic......................................... .................................. 850 rpm
Drivebelt tension (using a Borroughs tension guage No. BT373F)
New............................................... .................................... 125 +/- 25 lbs
Used.............................................. ................................... 80 +/- 20 lbs
Torque Specifications
Ft-lbs
Main bearing cap bolts............................................. ........... 69 to 83
Connecting rod cap nuts.............................................. ....... 40 to 47
Cylinder head warpage limit
Block surface........................................... .......................... 0.0059 inches
Manifold surface........................................... ...................... 0.0079 inches
Valves
Valve stem diameter
Intake............................................ .............................. 0.3138 to 0.3146 inches
Exhaust........................................... ............................ 0.3136 to 0.3142 inches
Valve face angle............................................. .................... 44.5 degrees
Valve margin width............................................. ................. 0.024 inches
Valve spring free length
'84 and earlier........................................... ...................... 1.803 inches
'85............................................... .................................. 1.909 inches
Valve spring installed height............................................ ..... 1.594 inches
Valve spring out-of-square limit............................................. 0.063 inches
Valve guide inside diameter.......................................... ........ 0.3154 to 0.3161 inches
Valve stem-to-guide clearance
Standard
Intake............................................ ............................ 0.0008 to 0.0024 inches
Exhaust........................................... .......................... 0.0012 to 0.0028 inches
Limit
Intake............................................ ............................ 0.0031 inches
Exhaust........................................... .......................... 0.0039 inches
Valve seat
Angle............................................. ................................ 45 degrees
Width............................................. ................................ 0.047 to 0.063 inches
Engine block
Deck warpage limit............................................. ................. 0.002 inches
Cylinder bore diameter.......................................... ............... 3.6220 to 3.6232 inches
Cylinder bore out-of-round limit............................................. 0.0008 inches
Cylinder bore taper limit............................................. .......... 0.0004 inches
Piston-to-bore clearance
'84 and earlier........................................... ..................... 0.0020 to 0.0028 inches
'85............................................... ................................. 0.0008 to 0.0016 inches
Pistons and rings
Diameter
'84 and earlier........................................... .................... 3.6196 to 3.6208 inches
'85............................................... ................................ 3.6205 to 3.6216 inches
Piston ring end gap
Top compression ring.............................................. ...... 0.009 to 0.015 inches
Second compression ring.............................................. 0.007 to 0.017 inches
Oil ring.............................................. .......................... 0.008 to 0.032 inches
Piston ring side clearance (maximum)................................. 0.008 inches
Crankshaft, connecting rods and main bearings
Connecting rod endplay (side clearance)
Standard.......................................... .............................. 0,0063 to 0.0102 inches
Limit............................................. ................................. 0.012 inches
Crankshaft endplay
Standard.......................................... .............................. 0.0010 to 0.0087 inches
Limit............................................. ................................. 0.0118 inches
Crankshaft runout limit............................................. .......... 0.004 inches
Main bearing journal diameter.......................................... ... 2.3614 to 2.3622 inches
Connecting rod journal diameter.......................................... 2.0862 to 2.0866 inches
Journal taper/out-of-round limit............................................ 0.0004 inches
Main bearing oil clearance......................................... ........ 0.0006 to 0.0020 inches
Connecting rod bearing oil clearance
Standard.......................................... ............................ 0.0010 to 0.0022 inches
Limit............................................. ............................... 0.004 inches
EDIT: It's called "Th-red" cause it doesn't allow me to type thread.
MA61 Daily - Factory Manual, 5MGE Converted
GA61+UCF11+Time+Money+Love= UZA61
2JZGE MA61 Conversion kit
22R-E Including Rebuild Kit & Cam for sale
Nice info.
seeyuzz
river
They're a great motor and oft-maligned for no good reason. New camchain and keep fresh oil & coolant in them and they'll last for 400,000km.
I probably wouldn't pay too much attention to that turbo recipe though, sounds more like someone who doesn't know what they're talking about, spruiking a few buzzwords/items/names they've heard![]()
They're a good motor for lasting the distance and hauling around cars that require plenty of torque (for a 4 cyl engine). However, that's about it.
seeyuzz
river
you'll enjoy this thread then:
http://www.celica-gts.com/forums/ind...ic=17474.0;all
Yeah, I've been in long contact with this guy, and he's a fellow engineering student like myselfI'm going with the same/similar TBs if it's too annoying to get one here, but I wanted the intake from 4 locations, not from a collected plenum, hence the megasquirt emphasis
Also I want to mock up like a double manifold. In between I can change the length of the runners as I please (just for tuning's sake). Anyways, everyone feel free to share your experiences with this beast!
I'll share mine...
In the summer of '09 as I was finishing year 12 I bought myself one of the cheapest running cars I could find. This turned out to be an '85 RA65. I fell in love with it, with it's faded panels and fun rideI bought it for something like $250 and a virus scan. I was pretty happy with that. Only 2 previous owners. A hair dresser sold the car to them in '86 and now it's mine. It was then I found out the car hadn't been serviced since '86 (when they first got it), and it was still rumbling along! Changed the oils and fluids, new shoes yada yada... The oil came out like goo. I drove it for another 6 months until the day before the rego ran out, it busted a welsh plug. I was like fuckin A! What a mad engine! Surprisingly so far (without the block internals taken out) barely any corrosion in the cooling, just the welsh plug had rusted. Shit load of rust in the coolant but most of that was from the radiator. I'll try to find a pic of it. Had about 1/2 the fins completely gone. So I'm rebuilding it, and just playing with it. If it dies, it dies and I'll either find another 22RE or I'll just get an SA63 donor and go 3SGE. Just cause I have nothing better to do with my life.
No worries. And with that setup I've seen a few on yodatech which are in Hiluxes for hillclimbs. Best check there for the turbo setup. No one does it here cause it's a hell of a lot easier to just go for another motor.
HEAPS of info on yodatech for 22REs
EDIT: And no I haven't done it![]()
I've been maintaining the 22R in my Hilux from 15000km (when my father bought it from gov auctions in 1997), to current day in my possession with 238000km on it.
Its a solid motor, but just so damn boring to drive. Not much character compared to a 3RZ or even the 2600cc EFI in the same age Rodeo.
Now the clutch is almost gone, the timing chain is making noise and PS pump is dying. Time for a conversion I think![]()
Westfield Clubman SEi - 4AGE Blacktop, T50
RN90R Hilux XtraCab - VT V6 (yeah yeah) ,4L60-E, 3.583 LSD
There not powerfull, but there solid motors, i've serviced a couple that were well north of 400,000k un-rebuilt too
1983 Toyota Celica Supra
lloyd smith has built a supercharged high comp motor here
high compression rebuild
298 degrree cam
microtech 11x
sc14 supercharger,
made 130kw from memory at 10 psi and around 370nm torque (could be wrong)
car blew a head gasket within 3 weeks
