oil filter for the 1g-gte is the same as the camry dunno what year or model thought
but the filter part number
is z148 or z418 cant remember which one correctly (ryco brand)
Hi, Can anyone please confirm if I am right in thinking that the thread on a 1G-GTE is 20 x 1.5?????????
Thanks!!!
Charlie.
Some kind of BMW
'97 Hilux Surf SSR-X LTD
..::VVTi 1UZ-FE::..
Z418 fuck u 10 char
KE38 - 2TG
MS65 - 1UZ
wtf is that supposed to meanOriginally Posted by emp?
He really just wanted to write "Z418" but he couldn't because of the character limit. I think he's just asking for the thread size guys, not the oil filter. Perhaps for a oil cooler?
lolll didnt know what he was refferign to with the comment
anmyway yeah i figured hees after an oil cooler or relocator but i didnt know what size the thread was so i thought maybe if he got the part number for the oil filter he can go to a store and measure the thread size from one of the filters there
i think it's 3/4 UNF, look up the filter they just said.
my 1UZ is 3/4 UNF, it's got a male/male fitting in the alloy piece, yours might be the same.
beer me!
Cheers guys...Just call me frank is correct! I have seena cheap oil filter relocation kit/oil cooler take off, and it is 20 x 1.5mm thread. I have searched high and low on teh net adn I can't see anyhere saying what my stock filter thread size is!!!!!!
Some kind of BMW
..::VVTi 1UZ-FE::..
firstly why would u want to cool the oil on a lightly modded 1g-gte unless ur running really thin oil
secondly cooling the oil too much is not a good idea too u might need a thermostat on the oil cooler line
dont know how true this is or not but someone here told me that the
oil going to the 1g-gte engine oil filter was cooled by the engine coolant
now obviously the engine oil and the various parts related is cooled via the engine coolant but the cooling of oil filter i have no idea
also another elcheapo way to cool the oil is to put metal piece the size of the oil cooler around the oil cooler with some cooling fins on it , helps a lil bit i seen one on ebay ages ago u could prob make ur own
Oil only works within its viscosity, it'd be quite possible for a hard driven car on a warm day to put it outside that range. Toyota even agreed and put oil coolers on a few cars of the era from factory.Originally Posted by purple5ive
yeah, mk2's came with little front-mounted engine oil coolers standard. they're not very big, about 200x75x15mm roughly.
automatic oil is generally flowed through a cavity in the lower tank of the radiator for cooling. you could run the engine oild through this if it has one in the radiator.
beer me!
Purple Five, firstly, who said it is that lightely tuned?, if a 200bhp n/a 7M-GTE has one from the factory, I personally think a 210 bhp 1G-GTE should have, - especially with the extra heat gererated by two turbos, and the higher rev limit!! - especially again as these things are prone to spinning big end bearings too... I have not heard about the oil being water cooled? I have not actually seen the block for about a year (talk about slow engineers!) but taht could esplain some of the pipes arounf teh oil filter housing..
The other point being the main reason I want this kit is becaue of the oil filter relocation. If I run an oil cooler (the relacation kit will give me the option to do this easily once the engine is in) I will use an oil stat with it, Helping forther keep the oil at the correct temp/viscosity.
Thanks Joe, but the thread on the 1UZ is different (according to my sources lol) using teh auto cooler might be an option, as I need to buya new rad anyway, and my car is a manual!!
Apparently these are the engines that share the following thread size! 1G-EU, 1G-FE, 1G-GE, 1G-GZE, 1G-GTE (U), 5M-GEU, 6M-GEU, 7M-GE, 7M-GTEU, 1JZ-GE, 1JZ-GTE, 1JZ-FSE, 2JZ-GE, 2JZ-GTE, 2JZ-FSE, 1VZ-FE, 3VZ-FE, 4VZ-FE, 1MZ-FE, 2MZ-FE, 1RZ-E, 2RZ-E, 3RZ-E, 3RZ-FE, 5VZ-FE, 2TZ-FE, 2TZ-FZE
Unfortunately it doesn't tell me what that thread size is......
Some kind of BMW
..::VVTi 1UZ-FE::..
this link for speco kits says most toyotas have 3/4" like i said. mitsubishi use 20x1.5mm.
http://www.speco.com.au/acccoolers.html
couldn't find anything specific for 1ggte.
beer me!
Cheers Joe... Interesting that two websites conflictI am suprised that a toyota engine uses an imperial measurment!
my source was froma place that sells TRD oil filters... but they didn;t lsit the 1uz at all!!
Some kind of BMW
..::VVTi 1UZ-FE::..
They're not prone to spinning big end bearings, they're just getting old and the virtues of poor servicing in Japan are taking their toll.Originally Posted by Karma Supra
I dunno exactly about the oil being water cooled, but if you look at the oil filter, you'll see where it bolts to is a little jacket around the fitting which has coolant hoses going into/out of it.
