Results 1 to 12 of 12
Thread: 4AGE 20v turbo upgrade
    Aug 2009
    Aruba Dutch Caribbean Islands
    Question 4AGE 20v turbo upgrade
    Hi, I was just wondering how much power you guys think will this setup pull out in my AE86 with a 4AGE 20v Silvertop engine. Yeah its a long list and I spent allot.
    So here it goes:
    Turbo: Garret T3/ T4 ball bearing Turbo.
    • Microtech LT10s ECU
    • New complete 20valve gasket kit;
    • ARIAS low comp. pistons 8.9:1 C.R.;
    • 4AGZE supercharger connecting rods;
    • ACL Race bearings with thrust washers;
    • Balanced and polished crank;
    • Cometic head gasket;
    • ARP Main Studs.
    • ARP Head studs;
    • TOGA High Volume Oil Pump;
    • 3SGTE 440cc injectors;
    • New original timing belt;
    • 3 point racing clutch;
    • Custom made air intake manifold;
    • Custom made exhaust manifold.
    • Denso Fuel Pump 950-0155 280Lph;
    • CXRacing Aluminum Radiator;
    • 2.5” intercooler tubing with hoses and clamps;
    • 25x12x3 Intercooler;
    • HKS Universal SSQV3 BOV;
    • Tial 38mm wastegate;
    • Manual Boost Controller;
    Any other recommendations would be highly appreciated.
    Default Re: 4AGE 20v turbo upgrade
    hard to say as we dont know what boost level, fuel being used, blah, blah the list goes on.
    Northern Territory
    Er and what sort of turbo exactly?
    yeah, bit more info then just garrett t3/t4, can we have a/r's or something else at least?
    Aug 2009
    I bought this turbo from a friend of my. Its actually a GT3076RL turbo 0.60A/R
    Here are the other specs:
    • Compressor Wheel Inducer Size (mm)
      52.78
      Compressor Wheel Trim
      48
      Turbine Wheel Exducer Size (mm)
      51.78
      Turbine wheel Trim
      84
    I'm planning to run on gasoline for now
    BTW I'm not changing the cams yet.
    Brisbane
    The most you can make with those injectors is around 300hp at the tyres.
    May 2006
    tas
    Quote Originally Posted by ArubaAe86 View Post
    What kind? octane value available at the pump in your area?
    Cams will help to achieve higher output, but the N/a cams maybe aggressive enough.
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    Aug 2009
    Thanks for the reply. The octane at the pumps here is about 93. Maybe later when I accumulate the money I can buy cams.
    Aug 2009
    Does anybody know what would be the best turbo for fast spooling. I'm planning on buying a turbo from Turbonetics, they have good prices.
    Turbonetics GTK series, possibly the 325/350/450 or the like. http://www.turboneticsinc.com/gtk
    OR
    Precision Turbochargers make some good units.
    Change to a 0.63A/R turbine too for what you are doing. http://www.powertune.com.au/precision.html
    Brisbane
    Decide how much power you want and what you want to use the car for.
    Then choose a turbo with an appropriate power rating.
    Jul 2008
    Auckland
    The turbo you mentioned will have good spool.
    For better spool a GT2876R would be the best bet and still be able to make 250-270kw atw.
    You will def need bigger injectors. around 600cc or even more to have head room.
    Now 9AGTE 410kw atw
  1. turbo upgrade for 1j
    By slipway_cresta in forum Tech and Conversions
    Last Post: 30-08-2010, 09:30 PM
  2. 1JZ Turbo Upgrade
    By spiller in forum Engine & Driveline Conversions
    Last Post: 02-12-2008, 05:01 PM
  3. turbo upgrade
    By AE_82 in forum Tech and Conversions
    Last Post: 09-05-2008, 12:48 PM
  4. 3sgte Turbo Upgrade - WRX turbo?
    By medwin46 in forum Tech and Conversions
    Last Post: 25-11-2006, 07:02 PM
