Results 1 to 8 of 8
Thread: 1UZFE ITB's Vacuum tank?
    May 2009
    Default 1UZFE ITB's Vacuum tank?
    Hey Im fitting some silvertop 4age ITB's on my 1uz and using Link G4 ECU for management.
    Just want to know what people have done for vacuum tanks.. I want to run the original 1UZ ISC valve (controlled by the ecu).
    I think its going to have to be a cube shape tank so that the ISC valve will feed all cylinders equally, not a long tube with the runners feeding into it like some ive seen..
    Anyway please post your thoughts and pics etc please and any advice as to what works and what dosent.
    Thanks
    Default Re: 1UZFE ITB's Vacuum tank?
    Have you got pics of the setup mate? I'm interested in everything related to 1UZ intakes
    -RM
    May 2009
    Im waiting for the ITB's to arrive from the USA, they are the OBX ones as seen on ebay, Im pretty sure they are just copies of the A1Turbos ones made in NZ which incorporate 20V 4AGE TB's
    Anyrate I shall upload a pic once I have installed them, until then.. im sure some people here have put ITB's on 1UZFE's what did you do for idle control guys?
    Quote Originally Posted by driftae76 View Post
    Check out Ed's 1UZ Supra on Toyota 1UZ-FE & 2UZ-FE V8 Technical and Performance Forums under the members rides area. He ran a vacuum tank in the valley that was fed from each ITB, and this had some kind of idle control system connected.
    You'll need to sign up to view this area but definately worth it.
    Just do load sensing as TPS vs RPM and don't worry about using vacuum at all.
    www.billzilla.org
    Toymods founding member #3
    Junior Member Carport Converter ecko's Avatar
    May 2007
    tasmania
    Yeah Lloyd ae71 has a vacuum tank that sits in the V
    will try get some pics
    Nov 2010
    tasmania
    the obx adaptors may or may not be copies of a1, but they use rip off pics of josh youngs engine which DID use the a1 setup.
    May 2009
  1. OBX 1UZFE ITB's
    By Bazooka in forum Tech and Conversions
    Last Post: 29-10-2010, 11:49 AM
  2. RA28 internal tank surge tank ideas
    Last Post: 24-11-2009, 05:07 AM
