Results 1 to 6 of 6
Thread: 1jz into hilux surf kzn130 [HELP]
    New South Wales
    Default 1jz into hilux surf kzn130 [HELP]
    Hey guys,
    being sick of my 1kzte motor, i have decided to put a 1j into the hilux surf. Couple of questions. I have done as much research and read up demons build, but cant find any1 to suit my questions.
    My 1kzte has a 30-41LE gearbox aka A304E. The 1jzgte also has a A304 gearbox, in saying that wil my gearbox bolt straight up to the 1j, USING the 1J flex plate and the Hilux Torque converter?.
    2nd Which sump to use? front or rear. The 1kzte have a rear sumped motor so using a 1j rear sump will work without any modifications?.. I've seen the 1j into a hilux with a front sumped 1j and thats was chopped and cut like no tomorow..
    Help would be greatly apprecaited and pics of build will be up as soon as i get these 2 main questions sorted=)
    thanks guys
    Apr 2011
    Default Re: 1jz into hilux surf kzn130 [HELP]
    Hey DRF,
    I just finished a 1 jz vvti R154 manual into yn85 2wd 2y.... I used the rear sump with no issues only thing that I think will be a problem maybe not a problem but messy will be changing the oil as the plug is right in the middle of the cross member..
    Axil
    Newest of the Noobs
    Jun 2010
    Quote Originally Posted by DRF786 View Post
    thanks guys
    no need to chop the front sump just relocate steering damper....
    Junior Member Domestic Engineer Hurricane's Avatar
    sorry but this is way off topic here. but this is the last place fools-gold posted!
    FOOLS-GOLD PLEASE DELETE SOME OF YOU INBOX MSG'S
    TELLS ME ITS FULL AND I CAN CONTACT YOU.
    dan.
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
    my relocated steering damper
    Jealousy is a curse
    New South Wales
    hey guys will post up photos, with the kzn130 hilux just needed to raise the engine and relocate the steering dampener..
  1. Hilux Surf doors on a hilux
    By INSANE_PAINT in forum Tech and Conversions
    Last Post: 24-10-2009, 09:46 PM
