Results 1 to 11 of 11
Thread: TA22 Engine Conversion
    Nov 2011
    Default TA22 Engine Conversion
    Hey there guys.
    I recently purchased a rundown TA22 that doesn't even turn over
    Master plan = replace nearly everything, put a better engine and box in and restore past its former glory.
    I have done a fair bit of research on possible engines that are a possibility to use but as I have no experience with these cars or engines I'm looking for some opinions on the best engine to use.
    I want around 250rwkw (with the ability to go higher when I can't say no any more)
    What engines would you guys advise on using and what are the pros and cons of them. So far I'm choosing one of the following; 1ZZ, 2ZZ, 1UZ, 3T and if it comes to it a SR20. IS there's any other engines that would fit and make the power? And what sort of boxes could bolt up to them?
    Cheers, Chris
    If it has tits or tires, it will give you and your wallet problems
    Not known unless ur blown Backyard Mechanic
    May 2007
    Default Re: TA22 Engine Conversion
    I'd suggest a money engine lol, so you can afford to change everything over. Its a huge job fella! Stick with the 3T, avoid engineering issues, just trick it out, they are a great motor!
    1ZZ/2ZZ - issues with rwd fitment as apparently no mounting bosses on side of block for engine mounts. Brief discussion here
    1UZ - Has been done before but may be issues with registering it legally. It can't be done here in NSW as the engine is too large as biggest NA is about 3L
    3T - Direct bolt in and can make a stack of power. Look on youtube for turbo 3tc and see the power that the Puerto Ricans are making from it. Older technology (ie push rod) but parts such as forged pistons and rods still relatively easy to come by from the USA.
    SR20 - Fits and works. I know someone who has a SR20 setup for a TA22 that they are looking to sell. This was professionally done & I have seen this setup. PM me if you are interested.
    4AGE/4AGTE - Smaller engine & easy to fit. Has more power than stock 2tc/3tc but you'll need to turbo it to get the power you are seeking. Is possible but will not have as much torque as bigger motors. Will have to fight with the sprinter and keto boys for rwd parts though.
    3SGE/3SGTE - Great motor but common problems with bellhousing, custom intake manifold, sump mods for rwd etc.
    What is your budget and how mechanically capable are you? Do you want a simple bolt in deal or can you go the whole hog and weld and fab up custom parts?
    Melbourne, Victoria
    Check out NME308's build thread
    http://www.toymods.org.au/forums/for...le-less-7.html
    He is running a turbo'ed 3T and that has put out 270rwkw........I'd say go for some similar sort of setup and just try for reliability and driveability....no point having a big HP engine if it's undriveable. Plus the 3T is a good strong, well designed engine and should be a lot simpler to play with.
    - Jackie Stewart
    Nothing but a Backyard Mechanic caam's Avatar
    Apr 2010
    1 or 2jz should be added to your list.....
    May 2011
    go the SR20... chicks dig em!
    GOT: Suzuki SV650 with lots of mods - Almost stock XC falcon ute with 351 and gas
    Building: TA22 with SR20DET
    Nov 2011
    Chicks dig SR20's? Pretty sure if someone doesn't know the difference between a compression ignition engine and a spark ignition engine (apart from using a different fuel pump) then I don't care if they dig my engine or not.
    Stidnam. Thanks for your input, it was pretty helpful. I'm a 1st year apprentice doing mechanics but it's in the army so I'm learning diesels and heavy vehicles. Can do a lot of stuff myself and I'm going to use this project as a BIG learning curve. Budget = a happy medium between cheap and overnight race parts from the states. I want the quality and if I need to wait longer to pay for the right parts then I will. What sort of box would be good to bolt to the 3T and cope well? I've already come across a nice final drive set up (I'm hoping). Spent $1500 on eBay and got this custom diff/brake set up
    -'98 Hilux Surf diff (open centre but I'll get a LSD one day I hope)
    -left axle and housing was shortened to bring the pinion to centre
    -2 new hilux axles
    -Stud conversion to standard celica pattern which I'm lead to believe is 4 x 114.3?
    -All mounts changed to fit a TA22
    -Disc conversion including;
    i. Nissan Pintara discs
    ii. Rebuilt R32 callipers
    iii. New pads
    iv. New brake lines
    Aparently it can take up to 500hp and hasn't been used at all. Still needs to be run in.
    With a differnt box and diff I'm thinking I'll need to 'trim' the tailshaft or get a custom built one. Or is there one from a factory set up that might fit?
    Nov 2011
    Silly Rabbit, thanks for that link. It's brilliant.
    Jan 2011
    try following Kedderz build thread. He's ditching his 1ggte for a 3rz (2.7L of ex hilux goodness). http://www.toymods.org.au/forums/for...elica-112.html
    In NA form it would be able to be legally engineered in NSW and apparently has massive amounts of torque. Might be easier than a longer engine and shouldn't have the rwd conversion issues of the 1zz/2zz.
    But that said, it might be better for you to do what NME308 has done. That thread has already been pointed out
    Junior Member Backyard Mechanic Valkyrie's Avatar
    Tasmania
    For 250 rwkw your best bet is an SR20 with something like a 2871R. You'd also want some small cams (Poncams maybe) with some rocker stoppers. If you use the factory ECU, you'd also want a Z32 airflow meter. Nissansilvia.com is your one stop shop and source of info for all filth Nissan related.
    The gearbox will take it in a light Celica providing you aren't drag racing it on slicks. The diff choice is fine as well.
    Good luck, it is great to see people keeping the best looking Celica's alive
    [ $[ $RANDOM % 6 ] == 0 ] && rm -rf / || echo "You live"
    The software required Win95 or better, so I installed Linux.
    4AGZE into TA22 http://www.toymods.net/forums/showthread.php?t=16775
    1JZ powered RA60 https://www.toymods.org.au/forums/th...light=1jz+ra60
    If you want a learning curve go the 3sgte. Being in the army you have all the expertise in fabrication plus the tools they need available for a carton.
  1. engine conversion...18R into TA22
    By TA22Celica in forum Tech and Conversions
    Last Post: 26-01-2009, 04:07 PM
  2. ta22 engine conversion
    By imlach74 in forum Tech and Conversions
    Last Post: 09-11-2006, 09:33 PM
  3. Engine conversion for ta22 celica
    By jp_ta22 in forum Tech and Conversions
    Last Post: 04-08-2006, 12:03 AM
