Same pump......................
hey guys will a 1jz powersteering pump fit onto a 2j? are the lines the same etc? i have a 2jz in my cressida and the powersteering is super light. ive already tryed to slow the flow in the line but didnt do much at all and have heard that the 1jz pump flows less then the 2j pump? can anyone confirm that? ive heard that there is a solenoid on the mx83 that needs to be wired in to the factory ecu but that is long gone and need other options as it gets hard to control with 500+ at the wheels.
10.0sec Cressida (SOLD) current build- caged ke38, 2jz, Glide, 42gtx, 9"
Jealousy is a curse
do you know if they flow different rates between the two?
Probably if you rev the motor harder they will flow more
Jealousy is a curse
Configure the ecu you are runing now to control the power steering solenoid?
just found out the x8 doesnt have pps so i cant wire it up unless i find a jzx81 rack.
Let down your front tyres a bit?
But seriously have you had a wheel alignment as you could adjust more caster into it which should make it stiffer but will want to make it return to centre quicker.
they are ways to help but i dont think you realise how light it really is. it needs to be changed as it is way to dangerous to leave it this light and i want it done right.
do the 1jz guys have troble with light steering?? try a 1j pump i rekon
cheers luke
not really sure but from what i heard it sounds heavery then mine. i think i will have to give it ago i reakon![]()
ive tryed the 1j pump and it didnt do anythingkinda over this problem. i need to find a jzx81 rack and try that.
I got a X81 rack... looking for a X7 rack well not yet trying to find out what has a better steering ratio.
[Gentlemen's Club]
why are you looking into the x7 rack? do you have the same problem.
anyone know what 1jz-747 is running? since he is running 8 and with a small front runner im guessing he doesnt have this issue lol.
