Problem: Mechanical fuel pump on hybrid died, replaced with electric.... now have redundant fuel pump bolted to block which I want to remove.
Solution: Need a blank-off plate (BOP) (as its a 3T block) to cover the hole up so I can take out the old fuel pump.
Question: I think from memory, the 2T-G block (that my dad has now thrown out
) was 88220, but had 88261 head fitted with EFI gear, so therefore had a blank off plate on the block. So, does anyone have
information which will help me get hold of another BOP - any information on which block models had the BOP, a toyota part number, or any other information (or even if someone has one lying around, PM me). River, you got any exploded drawings?
I know it wouldnt be that hard to make one, but I really would like to keep it looking factory, and measuring off a fuel pump would be a PITA because of the bit that sticks out (you know, the thingemebob, I dunno what to call it) and I dont want to get hole centres wronng and end up with leaks (which is half the reason I built a new engine - bloody oil leaks!). Anyones help would be much appreciated, thanks!
