1) T-50, or W58 with off the shelf adaptor/bell housing or whatever you decide you want to adapt, like a nascar 4 speed dog box. or be totally backwards and get a K-50, they bolt up.
2)200/212mm flywheel with stock or heavy duty clutch to suit ae86 corolla OR 9/5/3 ceramic clutch, metal twin plate, carbon/carbon twin. The exact clutch depends on your choice of Q1. Could even run a 225mm GZE flywheel and clutch if you chose W58 but these are heavy and there are better options, depending on money and power output.
3)Run the remote thermostat but point it forward from the back of the water pump to the bottom of the radiator or bolt on RWD cooling gear(not worth it IMO). Hook up the rest like normal. http://www.toymods.org.au/forums/tec...d-rwd-car.html Pictures are gone but the words still help.
4)Why are you modding the sump?
5)They don't "bolt up". They will however, bolt up to an adaptor plate that it bolted to the head. technotoytuning makes the adaptor.
What motor is it? big port/small port blue/red/red and black top? How much power are you hoping to make? It doesn't really matter but your questions are so vague. You could be making anywhere from like 50hp up to 450hp or something with a 4A which will change the answers a whole lot.
