Results 1 to 9 of 9
Thread: Sard Fuel Pressure Regulator Adjustment?
    Default Sard Fuel Pressure Regulator Adjustment?
    Hi guys,
    Im trying to get the celica started (finally) and having some issues with the fuel pressure.
    I have a Sard regualtor on there, but the pressure on the gauge is reading WAY off the scale, like over 100psi (pretty much topping out the gauge). Ive tried adjusting the screw on the vacuum fitting all the way in and most the way out and it doesnt seem to be making any difference.
    Has anyone experienced this before? Im worried its doing some damage being at such a high pressure. Its a 4age 20v engine with 1JZ injectors that have been cleaned and spray tested.
    Thanks,
    Dana
    Toyota Car Club (Qld)
    Jan 2011
    Default Re: Sard Fuel Pressure Regulator Adjustment?
    U need to wind it back to reduce the fuel pressure... But if its any help, for the last two yrs, mines been running 100psi, told my tuner, he didnt belive me so he put his own guage in and it was 100psi.... But my motor has its own ideas so dnt wory bout mine doing it, its on a 100psi becuase it has to for now... Ur pressure is just to high, so if u get it down, ur car will most likly start and not be flooded with fuel??
    But yea, wind it back, but all the way down and uve maxed the pressure...
    Is there fuel coming out of the return line?
    Quote Originally Posted by sillycar chick View Post
    Hi guys,
    Thanks,
    Dana
    I'll go check the return line.
    One thing I noticed if I take off the hose at the fuel rail it releases a fair bit of pressure.
    Ive also wondered if the injectors are just not opening at all (possible, this is first time starting with the ecu), Im just not sure how to test them yet.
    It's harder for the injectors to open with higher pressure, but the injectors not opening won't cause high fuel pressure as the fuel pressure regulator should still bleed fuel to maintain the set pressure.
    How have you plumbed the regulator in? something like this?
    yeaaahh turns out I'd plumbed the reg in wrong, I had worked that out before seeing your pic there charles but yep that's how its set up now.
    Thanks guys
    Now I just gotta sort out my ecu issues and hopefully its start time
    SPANNER CRAB Grease Monkey AE3SGTE's Avatar
    Jul 2007
    Are you still running the turbo? I take it thats why you have 1J injectors.
    If not you don't need the vacuum line at the top of the reg connected, you won't need rising rate if its running NA.
    yup turbo attached
