******I have no experience with the ST205 WTA cooler******
As a general statement, it depends what your turbo outlet temps are. If the pre IC temps are 150deg C, then 55 deg after the IC is not too bad on a 30deg day, but if pre IC is only 80 deg C, then it's not that great.
In the same token, if you have 5 psi of pressure drop across the cooler, then it's not much chop either.
You really need to compare both sides of the cooler (both pressure and temp) to work out where you are.
