Page 1 of 18 12311 ... LastLast
Results 1 to 15 of 270
Thread: MRP 7age/9age 1900cc Stroker Kit
    Jul 2008
    Auckland
    Default MRP 7age/9age 1900cc Stroker Kit
    MRP 7a (aka 9age) Stroker Kit
    After huge request we have designed a 7age/9age stroker kit (1900cc).
    This will not be your generic stroker kit with bad rod/stroke ratios
    (Others on the market use OEM style 4age pistons with shorter rods which brings the rod/stroke ratio down to 1.44 which is less than ideal in the modern world of building a good reliable engine!)
    The pistons in this kit are a special custom design where we worked with CP to get what we needed.
    Rod/stroke ratio is 1.52:1
    Custom MRP 90mm Billet 4340 Crank based on the TRD/Atlantic Crank Design
    8 Bolt to take 4age flywheels
    OEM 4age journal sizes so you can use the OEM 4age size bearings
    Oversize oil gallery holes which allows more oil to pass through the bearings
    Oil gallery chamfer lead in/out which aids in flowing the oil in/out of the gallery holes
    Oil gallery feeds are the same as the 4age crank meaning constant 360 degree of oil supply to the journals at all times unlike the 7afe crank.
    Large counter weights to dampen harmonics at high RPM,
    Dual crank sprocket keyway for those wanting to run this option.
    Custom MRP Billet 4340 conrods with ARP 2000 bolts
    Around 6% longer than the 7a rods
    I-Beam & H-beam available
    I-beam being the stronger but heavier of the 2 (These are like Argo Rods)
    H-beam is similar to Eagle, Spool etc.
    Rods are notched on the journals which acts as an oil squirter up into the bottom of the piston
    Custom MRP Forged Pistons by CP
    Low compression height, 20v & 16v available in both N/A & Turbo to any compression you require.
    Rings & gudgens supplied
    Power rating of the kit 800hp+ & 10,000rpm+
    $3750NZD
    Notes
    Must be used with a 7afe block
    No modifying of the block is required
    If your fitting oil squirters into the block from a 4age engine and worried about clearance, the crank has been designed to clear the oil squirters.
    Takes 4age flywheels
    Now 9AGTE 410kw atw
    Jul 2007
    Default Re: 7age/9age 1900cc Group Buy!
    will this require "clearancing" of the block or any other shenanigans of the sort? 3k for the full setup is bullshit cheap...
    any ideas on power and RPM ratings?
    also will we be able to specify whatever comp ratio we want?
    edit - pending the above, count me in.
    Oct 2009
    Fuck that's bullshit cheap, you would easily pay that for a regular 4AGE kit
    Aug 2012
    what is the pistons comp height for this kit? you can go for 25mm c-c like on Ninja zx14r to help rod length.
    incredible price!!!
    Jul 2008
    Auckland
    Yes you will be able to specify the comp ratio you want.
    The kit will be designed to handle over 800hp if needed.
    RPM ratings - thats up to how game you are! but should easily be around 9000rpm capable.
    Quote Originally Posted by liteace View Post
    incredible price!!!
    Piston comp height is the key in this kit and the pistons will be a special design. And yes its gona be tiny!
    The rod length we are using is around 6% longer than the stock 7a rods.
    Now 9AGTE 410kw atw
    Subscribbled
    Mar 2010
    Mississippi
    Count me in for a kit !! Just hope it makes it here before Christmas !!
    wrenchdad
    Jul 2007
    Quote Originally Posted by Bazda View Post
    consider me to be in at this stage then. ill let some other people know who might also be keen
    will keep the money ready and waiting
    SC14'd Member Domestic Engineer nick.parker's Avatar
    Canterbury
    Ok....I'm in too.
    I was already in the process of getting prices for custom rods and pistons to make a 1.6:1 rod / stroke 7AFE with standard stroke. But no point now
    == 4AGZE SC14 Supercharged ==
    Jul 2008
    Auckland
    We have pretty much sorted the crank and rods.
    Just working on piston designs with some usa companies (JE, Wiseco, Cp & Ross).
    Once they are confirmed we will be taking deposits.
    Now 9AGTE 410kw atw
    Top End
    Hey Bazda who is making the billet cranks ? do they do one offs for other motors
    Once apon-a-time world famous Photochopper
    http://zammothechoppa.deviantart.com/ : )
    Jul 2008
    Auckland
    Quote Originally Posted by Zammo View Post
    We cant do one offs, there is a minimum buy.
    Whos making them. We have a few suppliers in mind but not settled on 1 yet.
    Now 9AGTE 410kw atw
    Top End
    one off billet cranks are expensive and no one makes them
    I'm in bazda
    Don't mind me, just subscribing and going back to lurking while i try and figure out how i could possibly justify this... (it's unlikely, so don't count me in just yet)
    Toymods Club Member
  1. 7age: how to?
    By iflylo in forum Tech and Conversions
    Last Post: 03-12-2015, 08:02 AM
  2. 9age??
    By Bazooka in forum Tech and Conversions
    Last Post: 06-10-2012, 08:44 PM
  3. 7age 20v stroker?
    By 13anshee in forum Tech and Conversions
    Last Post: 29-08-2011, 10:03 AM
  4. 20v BT head on a 7AGE
    By chadix24_7 in forum Tech and Conversions
    Last Post: 09-03-2006, 10:00 AM
