Results 1 to 9 of 9
Thread: Forged pistons for n/a Gen 3 3S-GE?
    Junior Member Grease Monkey MattC's Avatar
    Oct 2011
    Default Forged pistons for n/a Gen 3 3S-GE?
    Firstly, yep I've googled this. Extensively
    I'm rebuilding a Gen 3 3S-GE to put in my ST162, and while there are any number of brands to choose from as far as forged conrods go, I can't find any of-the-shelf forged OEM-replacement pistons. It seems all that is available is low-comp 8.5-9.0:1 turbo slugs, or 12.0:1+ high-comp race jobs. I'm after a set in 10.5:1 or thereabouts, anyone know of anyone that makes such an item or am I going to have these things custom made?
    Thanks
    Matt
    Happiness is a warm Celica
    wa
    Default Re: Forged pistons for n/a Gen 3 3S-GE?
    Wossner do them, dunno how google missed them.
    Oops, just reread about not wanting 12cr, need to check what thickness hg thats to suit, you could fit a thicker hg to drop the cr a bit. Any if the gen3 mls good name brand hgs to suit gen3 3sgte will also be fine for the ge.
    wa
    having said that, any of the piston companies that make 3sgte pistons can make them to suit what ever CR you want. it's not a full custom piston and you'd still get them for a reasonable price.
    contact http://rsrace.com/store/index.php and ask them. let them know your after a package with eagle rods, cometic HG, acl bearings and ARP gear and they'll do a good price in my exp.
    Oct 2011
    Yeah I'd seen the Wossner pistons, they only seem to do high-comps off the shelf though. Thanks for letting me know about RSP, wasn't aware you could custom-order stuff to go in their package deals, I'll follow that up. +rep for you
    May 2011
    cant just use a 3sgte piston and run a .9mm head gasket? should get you close? deck the head and block job done?
    i thought ge and gte pistons where the same apart from the CR?
    1990 ST185 Running stock Gen 3 power, 216awhp at 15psi. 13.6 second down the quarter
    wa
    yeh, you could do that also, but i don't think a 0.9mm HG would get you there.
    other q is, do you need forged pistons? the stock gen3 already has 10.3:1, once you deck the block and face the head and fit a HG to suit you could easily have 10.5-11CR.
    wa
    I got my forged pistons made by Special Piston Services (SPS) in Victoria - very happy with them.
    http://www.specialpistonservices.com/
    Oct 2011
    Quote Originally Posted by aus jd 2703 View Post
    Yeah I had given that some consideration, once the block and head have been done I'll make some measurements and see if that's the most viable option.
    Quote Originally Posted by jonathan yee View Post
    Probably not, it's not going to be a racecar, I'm just going with a "do it once, do it right" sort of ethos, factory spec but with better and lighter bits. If however, the cost ends up being prohibitive I'll just use the factory pistons.
    Quote Originally Posted by Youngy View Post
    Thanks for that Youngy, I'll get in touch with them too.
  1. 3T GTE forged pistons?
    Last Post: 25-04-2022, 01:33 PM
  2. ACL forged pistons
    Last Post: 10-04-2010, 06:43 AM
  3. GZE forged pistons v aftermarket forged pistons
    Last Post: 17-07-2007, 07:21 PM
