If you insist on dodgy CAS try first to clean it thoroughly from metal particles that its magnet can, in theory, attract from somewhere
Best of all find someone with a scanner and see what happens upon your misfires. If you're lucky you will see some sensor's signal changes instantly and then settles back, for example this can be the case with coolant temp sensor.
I've personally seen live data from 1jz-ge's off jzs171 and jzx100 and if you got a laptop you can arrange your own scanner for under $50. Don't know though if earlier models support scanners.
Another possible option to find a faulty sensor is to disconnect sensors 1 by 1 forcing ECU into failsafe mode and see if problem disappears. Virtually every sensor can be disconnected this way while engine would still keep running.
