Results 1 to 5 of 5
Thread: Turbo dump pipe - is std 1.6 and 2mm mild steel exhaust tubing too thin?
    Forum Contributor Domestic Engineer
    Default Turbo dump pipe - is std 1.6 and 2mm mild steel exhaust tubing too thin?
    I need to make a new dump pipe shortly, and have previously used steam pipe. Don't want the weight and the heat capacity anymore, so was looking to do it in thinner tubing. Issue is, I can't get the sizes I need in a 2.5 or 3ish mm thick pipe with mandrel bends locally.
    Anyone know if 1.6 and 2mm mild steel will be too thin and burn out quickly due to the heat?
    Will likely ceramic coat it anyway to cut out some radiant heat around the brake lines etc, so that may help it last?
    Thanks for any help.
    MA71 - 7MGTE - 340RWHP
    Default Re: Turbo dump pipe - is std 1.6 and 2mm mild steel exhaust tubing too thin?
    That will be fine mate, I have not seen thicker stuff used much for a DP?
    Aug 2009
    Quote Originally Posted by boxh34d View Post
    hang on you used steam pipe for a dump pipe? after turbo it isnt needed and normal wall tube is fine
    Jul 2009
    that would have been a big dump pipe :O
    Yes it was way overkill - but I needed a dump pipe in a hurry, and I had the pipe on hand and couldn't get anything else mandrel in the time frame.
    Thanks fellas, good to hear that the 1.6 will be fine. Makes life very easy.
