IDL > E2 is effectively an open or closed switch. It should have low resistance when closed (zero is good) and infinite resistance when open. The factory ECU has a lot of tolerance built-in to allow for "creep" in the values due to deterioration of components and wiring, connectors etc over time.
As it happens I was also taking measurements yesterday. Here are the resistance values (from full closed to full open in kOhms) that I pulled off a spare throttle body with my $10 analogue multimeter...
E2 > IDL Zero to infinity (sudden change)
E2 > VTA 0.75 to 3.8 sweep
E2 > VCC 4.2 constant
IDL > VTA 0.75 to infinity (sudden change)
IDL > VCC 4.2 to infinity (sudden change)
VTA > VCC 1.0 to 3.9 sweep
Cheers... jondee86
