Results 1 to 15 of 18
Thread: big brakes and 15inch wheels
    Jan 2013
    Default big brakes and 15inch wheels
    I was wondering if anyone is running 294-300mm rotors with any 4 pots under 15inch rims and if so what type of 15 inch rims.
    just trying to get an idea of what rims have good calliper clearance
    CISCOKIDS
    The Gentlemen's Club
    Midnight Rocker
    Aug 2009
    Default Re: big brakes and 15inch wheels
    Minimum diametre inside my 15" 3pc Simmons is 360mm, so it all depends on what Caliper you can squeeze in the remaining 30mm if you use a 300mm rotor.
    Another factor is the wheel hub and spoke clearance...
    I run 254 rotors (10") and AP Racing 4 spots in my car leaving plenty of room and heaps of stopping power.
    Rgds, Willofan
    Jan 2013
    I will look at smaller sized disc with good calipers if i cant find anything that will fit what i have.
    Currently have Ford AU rotors with landcruiser 4 pots or R32 GTR disc and calipers all round. Was going to give these a go before i go looking for a new setup.
    CISCOKIDS
    Midnight Rocker
    Victoria, Mt Macedon
    MX73 wheels have lots of brake clearance. No idea what discs people have jammed in them though.
    Jan 2013
    I would like something wider then stock wheels. looking for a 15x9 or 15x10
    Clear. would rather an old school rim look but i guess i cant be two fussy unless i swap to smaller brakes
    15inch te37v 9.5j -20 offset
    CISCOKIDS
    Midnight Rocker
    Melbourne Victoria
    im using te37 v on my 45 celica with a 309mm rotor x28mm vented and ap 4spot caliper. wheels are 15x7 with a 0 offset
    Toymods Club Member Backyard Mechanic Big T's Avatar
    I run 4 pot brembos with a 300mm disk. There are very, very few 15 inch wheels that will fit. My avatar shows the only 15" wheel I have found that will fit... it is a f8 type watanabe copy made by Black Racing but the clearance was so slim that the balance weights were hitting the caliper. I assume that genuine watanabes will probably fit as well but have not tried myself. Even in 16" the pickings are fairly slim depending on spoke clearance.
    4agte finally completed. 234rwkw @ 8125rpm. Tis fun
    Jan 2013
    Found this on another forum AE86DC
    brakes
    rt142 corona rear disc brakes w/internal drums
    ss works front brake kit (r32 skyline calipers)
    r33 skyline non-abs brake master & booster
    braided brake lines throughout
    wheels
    ssr mark3 15x8 +13
    10mm slip-on up front
    CISCOKIDS
    Midnight Rocker
    Jan 2013
    From another forum i visit.
    Only gonna get a pair of more modern wheels to fit.
    http://ozdat.com/forum/down...891&mode=view
    32 gtst brakes and 15" meisters. Still needed grinded around the edges to clean JUST
    CISCOKIDS
    Midnight Rocker
    Feb 2010
    Auckland
    setting up my TA22 with R33 GTS-25T brakes all round. Have test fitted my mates Works equips 03 15x8 front, 15x9 (or9.5) rears. from memory the works wheels use the "T" or big clearence centre.. anything less would be smashing the spokes I'd imagine. May be able to grab a pic or three when I'm next in the garage.
    loves hi RPMS Backyard Mechanic
    AU falcoon 290mm rotor and AU falcoon caliper fits inside a 15" jap wheel. i have SSR dori Mesh and it clears them with miles of room
    N/A for life...
    This is highly dependant on your application. Different cars have different offsets for the brakes.
    The further inboard, the easier it is.
    Rally Celicas & Corollas use a special OZ racing rim over machined down (to 30mm) ST205 GT4 rotors & calipers.
    Earlier versions of the Impreza WRX 4 spots will fit under some special 15" rims as well.
    Apparently, the Wilwood calipers are quite small & have been known to be under smallish wheels on Escorts & Mazdas.
    Jul 2007
    My AW11 is running an MRP brake upgrade kit which includes 286mm rotors and 4 pot calipers which are a copy of brembos. they fit behind my buddyclub P1s with no issue.
    Jan 2013
    Thanks for the info guys.
    I understand that it depends on the setup but a rough guide/idea is better then nothing at all.
    CISCOKIDS
    Midnight Rocker
    I have a 300ish mm rotor (300?304?) cant remember, and Performance friction ZR34 calipers (4 port single piece, ducks nuts sorta thing) and they fit inside my Rays meshies, steel outer, mesh inner.
    I wanted to get TE37V for my track tyres, but Rays very vaguely told me they would not fit. I really really wanna test fit someones to see if they will, but I need to actually get it all on the car before I do that...I am pretty sure they will fit, but, I dont wanna outlay the money to find they dont....
