Originally Posted by
ShanePedler
Hi guys. I realise this is an old thread. I have a UZS131 running gear put into a Mazda B ute. Last night, I was getting the same symptoms as described above. Worth adding, is the problem seems to only occur after driving for 10 minutes. Also, the transmission reacts in accordance to the erratic speed display on the dash. So, if the speedo drops to 0km/h, the gear box will be stuck in first gear. If the speedo jumps to 180km/h, the gearbox will go up into forth gear. I replaced all the electrolytic capacitors in the ECT (and separate ECU) about 4 years ago so I doubt the problem is that. I'm thinking it's the electronic speedo drive or a connection thereabouts. I'll post an update when I get around to looking at it.
