Results 1 to 6 of 6
Thread: TA22 air con wiring diagram
    Aug 2009
    Default TA22 air con wiring diagram
    Does anybody have a wiring diagram for TA22 air con unit?
    I searched forum but get everything involving TA22 but what I need.
    I bought air conditioning unit for inside a TA22 but has no wiring or controls with it.
    Junior Member Domestic Engineer TA22 GT's Avatar
    Default Re: TA22 air con wiring diagram
    Check this link
    http://img.docstoccdn.com/thumb/orig/26737389.png
    The main plugs should already be in the car. There's a control box that bolts onto the evaporator that's under the glove box as well as the on/off control that is on the outlet vents. Sounds like you don't have the control box, it's grey and about 100x100mm and about 30mm thick...
    Aug 2009
    Thanks for your help guys. I realised when looking at it closer it is an aftermarket under dash model with no amplifier module or switches or wiring. Looked at toyodiy and found same unit was used in a TE47 Gt model but part numbers don't exist, so finding parts could be difficult.
    fairly sure I have a factory amplifier unit if you want it
    Aug 2009
    Stidman Would be great if you have one, pm me with how much you want and we can work out best way to send it.
  1. Replies: 6
    Last Post: 08-01-2009, 12:57 PM
  2. After Wiring Diagram
    By makoman in forum Tech and Conversions
    Last Post: 12-12-2007, 11:32 AM
  3. TA22 with OK Monitor - Wiring Diagram Wanted
    By 71TA22 in forum Tech and Conversions
    Last Post: 12-10-2007, 04:02 AM
  4. gtv TA22 wiring diagram wanted
    By 74gt in forum Tech and Conversions
    Last Post: 12-01-2007, 10:30 AM
