Its the other side... The Intake side thats a Barrel of fun!
You will need to remove the heat exchanger due to bolts getting in the way behind it.
This is done by removing the big brass bolt looking thang.
Now with everything, You will need to continually customise things. The custom engine mounts are no exception.
Get the Grinder out again
You will need to remove the motor a fair few times to get it right so leave the gear box off to start would be a suggestion
The rear turbos do fit - However you will NEED heat shields to make sure everything does not implode
Cooling is an issue.
The factory aristo thermo fans do not fit. They foul on the aircon compressor. so After you go to all the effort of getting them fitted to match up to the radiator you will find that they are too big. Damn.
