Results 1 to 4 of 4
Thread: gs300 2jzge vvti immobiliser help.
    Sep 2014
    Default gs300 2jzge vvti immobiliser help.
    I've got a ma61 with a 2jzge vvti out of a gs300 bolted into it, conversion has grinded to a very depressing halt as i've realised that gs300's had a immobiliser factory fitted. I bought this engine a year ago and never got the key or immobiliser off the guy cause it was already pulled from a car. Is there ANY way to get around this or do i need to pull the motor and sell it and buy a new one. I don't feel like spending $1k on a stand a lone ecu to run my $500 engine is worth while. Surely i can get the ecu flashed or something.
    Sep 2009
    Default Re: gs300 2jzge vvti immobiliser help.
    Try talking to dumbass on here. You may be able to get a used immobiliser ecu and have a key coded to it. You also need the correct aerial that goes around the key.
    What about an ecu without immobiliser?
    Jealousy is a curse
    May 2010
    Moscow
    No such ECU was available from factory for the particular car
    However I can sell one or modify your unit, PM me if you're interested
  1. JZS155 Crown 2JZGE VVTi Wiring Diagram needed - HELP
    Last Post: 30-04-2013, 07:28 AM
  2. 2jzge vvti Code 59.....Help
    By chris78 in forum Tech and Conversions
    Last Post: 31-07-2012, 06:08 PM
  3. 2jzge vvti TPS question NEED HELP
    Last Post: 31-07-2012, 06:31 AM
  4. 2JZ-GTE VVTi front cut into Aus JZS160/161 GS300 - How difficult?
    By Sicarius123 in forum Tech and Conversions
    Last Post: 20-05-2009, 06:13 PM
  5. 2JZGTE VVTi Immobiliser
    By grahamd in forum Tech and Conversions
    Last Post: 05-06-2006, 08:54 PM
