This is worth checking I guess. It doesn't seem like its running on 5 cylinders which is what I would assume this would do, but I will check it and report back.
Funny thing is, it didnt run on 5 cylinders...it started/idled great, fine off boost, and fine to around 4000rpm on boost, then a wierd miss.
I doubt a knock sensor would do that, my experience has been if the sensor senses knock it throws a code and drops into limp mode....
Just a thought...is the ECU a JZA70 one? If so, have you had a look at the capacitors on the circuit board?? Its a known issue the caps start to break down (chinese rubbish, unlike those used on the previous 7M's and later JZA80's which were better quality Japanese)...its a reasonably simple job to replace the caps (couple dollars worth of parts) which can cause all manner of strange things including massive over fuelling....worth a look
