Now, the “Suction pipe” must be modified or it will foul on the s/c unit making it unable to fit. You will start with a pipe that looks like this :
And you have to grind down the casting dags and the lower fixing bolt sleeve so that the pipe is smooth, allowing more room for fitment.
Now is a good time to plate the ABV hole .
Next we can get to the intake plenum, remove the lower right hand bolt fixing point, so it looks like this :
The s/c unit must have the charge pipe removed prior to slipping it down behind the motor. Watch out as it gets tight and squeezy but it does fit with a wiggle.
Spacer : this is the aforementioned washer that holds the unit from shifting forward and backwards on the bracet.
