Results 1 to 9 of 9
Thread: Supercharged vs turbo 4age
    Aug 2018
    Wellington
    Default Supercharged vs turbo 4age
    Hi
    Supercharged vs turbocharge 4AGE or 7AGE, nothing specific about hp or torque just getting an idea of what people did or wished they did. i have a 7AGE and cant decide on what type of forced induction i want, 230hp i my minimum goal. all opinions welcome.
    Thanks
    Default Re: Supercharged vs turbo 4age
    You can get really good response with modern turbos if they're moderately sized.
    I wouldn't choose a supercharger for a 4age, but thats my opinion. For a high-revving engine, I want it to make its power up high.
    If thats only 230hp at the engine, you could probably make that with something as small as a GT2554R which should have awesome response on a 7age.
    look at turbo options on the garret site https://www.turbobygarrett.com
    Aug 2018
    Wellington
    Thanks, iv heard the Garretts have a bit if lag to them, is this true?
    depends which turbo. Apparently the newer GTX Gen II are heaps better though.
    Jul 2007
    Turbo. Borg warner efr6258
    i've done turbo and s/c. turbo is better bang for buck but ultimately its a personal choice (unless you are trying to win races)
    Victoria, Mt Macedon
    I've had a 4AGZE for years. The advantages are that it is essentially a stock motor, so somewhat less messing around to get it in and running. It also makes torque from the basement, put your foot down at 1500rpm and you have boost. Peak torque for me was 3200rpm form memory. Enough power to be fun (110rwkw) but it didn't set the world on fire.
    A well selected turbo will definitely make more power, and with modern designs should have minimal lag. But the low RPM response will still be missing.
    Horses for courses. Try and drive a few and see what you like.
    oregon
    Quote Originally Posted by Hen View Post
    a 4AGZE I built for a client a few years ago.....
    I've had both for years and love either platform. Kind of depends on what the car is used for IMO.
    The gt2554r Adam mentioned above is an animal, spool is that of a supercharger. On my 4ag though it came in just under 200rwhp/315nm (basically a stock 4agze smallport), so the bigger displacement of the 7ag might just give you the HP you're after plus the response of a supercharger anyways.
    OST.. how did that thing go with the 82mm bore? Hold up fine? No issues with cooling?
    I see you're in Wellington. Maybe a good chat with Barry Manon from MRP is in order, he'll steer you in the right direction plus be able to supply you with everything you need.
    oregon
    Quote Originally Posted by feral4mr2 View Post
    none that I've heard of... but the client is half way around the world. 82mm on a 7 rib block isn't usually a problem
  1. XV20 camry 1mz-fe any one turbo or supercharged one
    By Luxnut in forum Tech and Conversions
    Last Post: 27-05-2011, 11:54 AM
  2. valve sizes for supercharged engines - 4age
    By Dangerous Beans in forum Tech and Conversions
    Last Post: 10-09-2010, 12:17 AM
  3. supercharged twin turbo 2jz - lets brainstorm
    By pandaah in forum Tech and Conversions
    Last Post: 04-11-2009, 12:44 PM
  4. aw11 with 100 kw small port 4age supercharged
    By robakka in forum Tech and Conversions
    Last Post: 22-01-2007, 02:47 PM
