Originally Posted by
adamaw11
Car is an '88 aus delivered AW11, stock brakes.
I find my brake caliper slide pins keep seizing up.
I clean them and regrease them, but every time I've checked them again after driving the car, I'll find the pin is seized quite firmly, takes a fair bit of force with pliers to get the pin to move, to then take it out and clean it again.
Its usually after a track day I'll check them, since I'll find the brakes will loose a lot of bite.
Is this just a symptom of old brake calipers? as they have 330000 ks on them, can't actually get brand new calipers anymore, and secondhand replacements might have the same problem.
I was quoted $600 to recondition the calipers.
I'm using high temperature bearing grease (Castrol HTB 2) on the pins. Is there a better option that won't seize up so quickly?
Or do I just need to clean the bore out more thoroughly?
Adam.
