Results 1 to 15 of 18
Thread: Can an oil pressure sensor be used for fuel??
    Default Can an oil pressure sensor be used for fuel??
    I was thinking of trying to use an oil pressure gauge transducer to monitor my fuel pressure and make sure my pressure doesn't drop or surge?
    Anybody know any reason why you can't use an oil pressure gauge sensor for petrol??
    Junior Member Grease Monkey Cruiser97_80's Avatar
    Tasmania
    Default Re: Can an oil pressure sensor be used for fuel??
    i can't see why this wouldn't work as long as the sensor didn't break down from fuel exposure . That would be nasty!!
    1990 ST185 GT4 3SGTE
    1991 ST184 SX 3SGTE
    1991 SW20 GT 3SGTE
    1998 ST215 GTT 3SGTE
    2008 VDJ200 Sahara
    Just Another Part Time Grease Monkey
    My dad has a 2.6 efi Rodeo, which has a bad habit of fuel pumps dying. He has an oil pressure sender with gauge on the fuel line so he knows when it has happened again.
    So far it has been a few years with no issues.
    Montrose
    Oil pressure sensor SHOULD(!) be petroleum resistant, and have no problems. It'd be a bit of a worry if it did!
    south australia
    yeah you can. i pulled a setup out of an R32 on the weekend. they had an oil pressure gauge used for fuel pressure on a second fuel rail that had two extra injectors in the intercooler pipe.
    it seemed to work fine, no leaks and the gauge was reading good. i would say that its all good to go ahead with.
    Thanks guys. Very helpful.
    Now I just need to go and buy one. Haven't bought gauges for a long time. VDO used to be a good brand. What is the go these days??
    south australia
    yeah, and autometer. there are several japanese brands that are also good and look pretty sweet when lit up.
    you know you have to use the electrical type and not the mechanical sort. (im sure you are aware tho)
    I've had a VDO oil pressure gauge attached to my fuel rail for years, no problems.
    You're better off getting a proper fuel pressure gauge though as they have a more meaningful scale (ie you're not likely to see 100psi of fuel pressure). As mentioned Autometer make some nice ones:
    http://www.autometer.com/cat_gaugesearch.aspx
    Forum Sponsor Grease Monkey
    I've had a $25 super cheap auto oil sender and gauge connected to the fuel line for a few years with no problems
    yes any pressure gauge can be used if it reads to the numbers you need! but because of the pulsing from fuel pressure if you dont use a liquid filled one they will die much much quicker and not give you a nice smooth reading!
    Thanks again for all the replies.
    I should really give some feedback points for all this excellent advice. Add to reputation etc.
    This one fits my budget.
    Quote Originally Posted by camrygt?
    Defi & VDO would be my choice for the guages
    Viagra Enlarged Member Grease Monkey TRAV-KE55's Avatar
    Yes you can, i actually rang the manufacture of the gauges that we had installed ina customers car and got htem to send a 2nd oil pressure sender, i then put it in the fuel line and use a rocker switch to read between fuel pressure and oil pressure, and its been handy and accuarate as.
    Trav
    Active Corolla abuser!!!
    Travis Robson
    0418 552 413
    Junior Member Grease Monkey go_the_datt's Avatar
    theres also speco gauges http://www.speco.com.au/gauges.html
    i dont know what their like but this is what im about to run in my car. when you need all your gauges i cant see the point of spending $2k on autometer.
    i read somewhere that in a "guage test" in a mag with all boost gauges that speco rated fairly highly in the accuracy stakes
    I can honestly tell you that they arnt that great (speco gauges) they arnt accurate and there diffirence in temp reading changes accuracy throughout the range. upto 20 deg c diffirence at an eng temp of 86 deg c the gauge reads over 100 deg c. Spend a little extra and get some VDO gauges.
    Trav
    Travis Robson
    0418 552 413
  1. Aftermarket engine management and injectors
    By benjamin in forum Tech and Conversions
    Last Post: 14-05-2006, 02:05 PM
  2. Tappet Pressure how much is too much ?
    Last Post: 03-05-2006, 10:36 PM
  3. 1jz Oil Pressure
    By 1JZ.747 in forum Tech and Conversions
    Last Post: 23-01-2006, 04:32 PM
  4. 3SGTE oil pressure maybe low?
    Last Post: 12-01-2006, 04:40 PM
  5. engine pinging
    Last Post: 15-12-2005, 01:15 PM
