Page 1 of 3 123 LastLast
Results 1 to 15 of 39
Thread: "Flat Spot" in Aisan Carburetor
    Selangor
    Default "Flat Spot" in Aisan Carburetor
    My current 3K carb had been giving erratic idle
    problems, so I have just reinstalled my older 4K
    Aisan carburetor, which had been lying idle in my
    room for a year. This carb was actually purchased
    new two years ago.
    The older carb idles somewhat better, but it tends
    to have what I believe is called a "flat spot". As one
    opens up the throttle pedal just above idle speed,
    the engine will hesitate, sputter and shiver a bit, idle
    speed dropping way down for a moment, before it
    revs back up as the throttle is opened further.
    Might this be caused by a dirty or faulty accelerator
    pump ? Or perhaps also a dirty "progression hole"
    like the type found in Hitachi carburetors ?
    http://dimequarterly.tierranet.com/a...ing_guide.html
    I wonder if spraying carburetor cleaner copiously
    into the throat might help ?
    I've also thought about pouring 3 or 4 bottles of those
    tank-type carb/injector cleaners into the fuel tank at
    one go to raise their concentration in the petrol, and
    hopefully improve the cleaning power enough to
    flush the carb. Might this be safe to the fuel rubber
    and metal piping and fuel pump ?
    These Aisan carburetors are really problematic.
    Default Re: "Flat Spot" in Aisan Carburetor
    Check to see if the accelerator pump lever is not bent. I recall a few people having a similar problem where the lever was already down before the throttle was opened.
    Just a thought
    -Phil
    its your tune
    mine used to do that, and i cant for the life of me remember exactly why but try tuning it yourself or getting it tuned
    it may be that throttle lever arm that gives a little squirt of fuel but i dont think so
    Cleveland QLD
    Hi
    With the car not running remove the air filter lid and shine a torch down the carby. You should be able to see the accellerator pump squirting a stream of fuel when you open the throttle. This is required because the initial air stream reacts faster when the throttle butterfly is opened and leaves the fuel behind that is metered through the primary main jet. So the accellerator pump tries to account for this delay. This sounds as though this is your problem especially that the carby has been sitting around. Have a look as described and see if this is the problem. I hope this helps.
    Todd
    Junior Member Backyard Mechanic sam-131's Avatar
    sounds to me like it's running too rich
    off the top of my head i think that the idle jets that are too big
    yeah, i think rich is right makes it bog down then frees up
    what motor is this on tham?
    best bet to not to even think about those heap of poo Aisan carbs and buy your self a weber 32/36 there worth there weight in gold fully tuneable i've got one and i've never had a drama
    32/36 is usually a bit big on a 4k and needs jetting down...wat motor r u using it on man'?
    Selangor
    Quote Originally Posted by Pure_In_Sanity
    Just a thought
    -Phil
    Thanks. I checked and the accelerator pump lever
    didn't appear to be bent - it looks fully up at the
    closed throttle position.
    Quote Originally Posted by love ke70
    32/36 is good for 1.2 to 2.4lts i got mine on a rona motor (2sc) bog stock bar a shimed head and an exhust
    you should allways rejet a carbie if it wasnt jetted for specific engine my carbie was on a l20 and it need the primarys and seconderys fixed up it was allover the shop
    Selangor
    Quote Originally Posted by toddw
    Hi
    Todd
    Thanks, Todd.
    I went to have a look down the carb's throat
    just now. It did squirt fuel when the throttle
    was opened, but the stream seems extremely
    small and thin.
    The squirt response appeared a bit slow in
    response to the amount of throttle movement.
    I'm not sure if it was due to my finger opening
    the throttle lever inconsistently each time, but
    sometimes the squirt was lesser, others more,
    and yet others none at all.
    Selangor
    Quote Originally Posted by sam-131
    Thanks, Sam and Love KE. It's on a 4K motor.
    I opened up the bonnet just now and tried turning in
    (clockwise) the idle mixture screw two full 360 degree
    turns (any more than that and the idle starts getting
    uncontrollably erratic) to make the mixture as lean as
    I could, but it doesn't seem to help much.
    yeah my 4k was a bitch to tune.
    it may not be the idle mixture screw as the issue is happening as your opening the throttle
    the jet of fuel is always rather thin so dont stress there
    when you were playing with it. when you turned the throttle just a little bit, did u notice the lever arm move and pump in a shot of fuel then the main stream comes in and continues as u open the throttle more
    try playing with the other mixture screws and see wat happens
    make sure you always remember what you did to each screw so you can go back to square one and try it all again!
    g/l mate
    Junior Member Domestic Engineer Hurricane's Avatar
    ok well to set the mixture setting run the car turn the needle in all the way till it stopss, then turn it two turns out and see what its like then? but yeah also see if the accleitaror pump is workin ok, becouse that will mostly be it, me thinks but what ya can do it just pull the carby apart (not that hard) just make a note of were every thing came from then clean all the jets out and make shore that there not block and that, and most of th time ive found that if ya good enough ya can still use tha old gasket to unless ya rip it too bad
    OH and ya dont need to seal the gasket with any thing ether.
    C how ya go man?
    Cheers, DAN
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
    Cleveland QLD
    Hey Tham
    It should start squirting as soon as you move the throttle. Check the linkages as some of them thad some small amount of adjustment.
