yep beside the fact you need a test spring of a known weight to make sure it reads right
that them into a good suspension place!
Just wondering if anone preferably in Syd has the facility to accuratly measure the spring rates in suspension coil springs.
I have built a dodgy machine using bathroom scales and a scale rule but its too bloody dodgey and i will probly end up with a coil spring imbedded in my head if i try it again![]()
As all the local suspension joints say you want to measure WHAT ????![]()
Suggestions anyone ?
MY BELOVED AW11...Updated members ride thread>>>>http://www.toymods.net//forums/showt...=4584#post4584
AW11s always welcome in my driveway !
allsprings at liverpool have the machine that will do the job.
Noltec at Thornleigh can
How precise does it need to be? You can use an online calculator using a few basic measurements:
http://not2fast.wryday.com/chassis/spring_rate.shtml
Note this only works for linear springs, not progressive.
Eddie.
4agte finally completed. 234rwkw @ 8125rpm. Tis fun
Pube and Turbo thanks for the info![]()
Big T, thanks for the calculator, i have a couple of these as well and have used this one as well![]()
I have got a pretty good idea using both the spring calculator and my home made tester (but got inconsistent results + - 20 %) i am keen to get a more accurate idea before i start changing spring rates.
