Results 1 to 11 of 11
Thread: Silicone Spray for Noisy Belt ?
    Selangor
    Default Silicone Spray for Noisy Belt ?
    My airconditioning belt has been making
    some mild screeching noise when the
    compressor cuts in.
    Might spraying some silicone lubricant, or
    better still, rubbing a little of that Perma Glass
    silicone liquid meant for renewing wiper blades,
    along the belt edges do any good ?
    Default Re: Silicone Spray for Noisy Belt ?
    Run a bar of soap under the belt.
    Yep Silicon Spray works a treat for squeeling belts.
    wouldn't all that make it slip more? shouldn't it not be slipping?
    Considered getting a new belt?
    Dry Lube and BeltGrip are a couple of products that come to mind.
    Are you sure its the belt, and not the compressor itself?
    Selangor
    It's the belt. I had the aircon man check the
    compressor and he said the clutch bearing,
    etc, is still ok.
    Er..... the belt was replaced just about 6 months
    ago. These Japanese "Bando" belts have gone
    down noticeably in quality over the years.
    Junior Member Grease Monkey Pr0j3kt_SuPrA's Avatar
    have u tightend the belt tensioner?? maybe the belt is just loose and just needs to be tightend?
    vic
    I disagree , a bando belt will still do 200000 klm , maybe not over 30 yrs but over 10 years it will .
    The genuine belts are twice as good as the non gen belts.
    D
    south australia
    spraying the belt can fix it, but it can also be abit of a bandaid jobbie. you might find that it will last for a little while and then it gets noisy again once the lube wears off.
    tighten the belt, it may be that. it might even be a noisy bearing in the pulley???
    another quick fix is chalk, or take the belt off and rub off the shinyness with fine sandpaper
    or steel wool.
    Selangor
    Thanks, everyone. The users in this forum
    are really helpful and prompt.
    The idler pulley tensioner has been tightened,
    and the bearing replaced recently too. I'll try
    replacing the tensioner though.
    Wonder if the pulley groove is worn out too,
    maybe I'll need to replace it as well.
  1. squeeling noise from timing belt -4AGE- ITS BACK! :(
    By WHITCHY in forum Tech and Conversions
    Last Post: 13-01-2008, 07:42 PM
  2. 4agze supercharger belt prob??
    By 4AGZE_rolla in forum Tech and Conversions
    Last Post: 02-07-2006, 04:50 AM
  3. hvlp spray guns
    Last Post: 29-04-2006, 11:49 AM
  4. 1GGZE Fan belt listing
    By SIKPUPY in forum Tech and Conversions
    Last Post: 22-02-2006, 03:45 PM
  5. fan belt 1j
    By chrisjza70 in forum Tech and Conversions
    Last Post: 17-01-2006, 09:47 PM
