so if the reference one is moving in a clockwise direction.. the other one is also clockwise? or counter-clockwise?
can you give a bit of a 3D layout for how the cranks will be situated?
vague ideas are solid cranks and pushrods, gears with fine chain (like mini timing chain) or alternatively, a dual cable setup as used on some bikes, so the actual direction of movement doesn't matter in the end...
of course direct mechanical connection is nicer....
by having a crank that has pushrods to the two things.. and having the crank at 90deg to their motion, you can muck around with the angles a lot more..
awaits 3D pic![]()
